It is currently Mon Jul 21, 2025 12:16 pm
Post new topic Reply to topic  [ 47 posts ]  Go to page Previous  1, 2
PostPosted: Wed Dec 21, 2011 4:39 pm
First name: Jim
Last Name: Hansen
JRessler wrote:
I don't think the pre-wired pick guard will work with this - it is set up for 2 humbuckers - let me know if you need help when you get to that point - good luck!
I had linked this earlier in the thread as a possible suggestion
http://www.guitarfetish.com/Wired-Strat ... p_896.html
He's at the stage now where he needs to route for the control cavities and drill/route for the pickup and jack leads. Probably best to wait until you have the pickguard and bridge to finalize those things.
Get the bridge located and then locate the pickguard, then plan your routing from there.
Jim Hansen
PostPosted: Wed Dec 21, 2011 4:50 pm
First name: Mark
Last Name: Sorrentino
In my experience, the angle of the neck, if present, has more to do with the type of bridge you're going to use rather than it being bolted on or glued in. I worked on a friends guitar who had a bolt on neck with a bigsby tremolo and floating bridge. The person who built this guitar did not take bridge height into consideration when installing the neck, and as a result, the action was way too high no matter how low you set the bridge. And to my surprise, when I took off the neck, there was even a piece of paper in the neck pocket helping to angle it to a small degree (obviously not enough). If there was a money involved in fixing his guitar, I would've re-routed the neck pocket and then filled and re-drilled the holes in the neck. But since it was a more casual tune up, I simply put thicker paper into the neck pocket (not the real way to fix this but it worked okay).
There's definitely ergonomics to consider when installing a neck. It's definitely easiest to keep the neck pocket flat, however if you have a floating bridge, which is typically quite a bit taller than hardtails, to make the neck high enough for decent action to be possible, your neck might be sticking way out of the body, and trust me, that typically makes a very ugly and awkward to play instrument.
So the better way to do that scenario is to route for a slight angle of the neck. This works fine with bolt on guitars as well as set necks. The result is much cleaner and easier to play.
That's my two cents
PostPosted: Wed Dec 21, 2011 6:00 pm
First name: Big
Last Name: Jim
Thanks , yes thats the link I followed and I have bridge and pickguard . Just have to make a template or get a template for the plug and main control cavity now.
PostPosted: Sun Jan 22, 2012 8:41 pm
First name: Big
Last Name: Jim
Does anyone one have a template or a drawing to help me locate the Main cavity and the jack cavity for the Strat I am building . ( 2 ) Humbuckers . I really didnt want to spend money on a template since I probably wont build to many Electrics .
PostPosted: Mon Jan 23, 2012 7:53 am
City: chicagoland
State: illinois
i've made strat type jack holes( :D ) using a drill and chisels. its kinda a pain. but Fender just does a deep oval hole. the lip of the jack plate should cover the edges of the cavity, so it is not rocket science, i'd just draw the outine of the jack plate and start digging.
as far as control cavities, again, the pickguard will cover it all, so again, just approximate. if you have a pickguard, then that is your template.... Fender routed out either one big "swimming pool", or 3 individual cavities for the pickups, joined by a wiring channel.
most bolt on necks benefit from a small shim in the neck pocket; i like to use sheet aluminum flashing. doesn't take much thickness to get it dialed it. most Strats have an allen screw tilt adjust. photos courtesy of Stew Mac. i believe Musikraft will also show pics.
PostPosted: Mon Jan 23, 2012 2:24 pm
First name: Big
Last Name: Jim
laughing6-hehe
Filippo Morelli wrote:
It's a strat. Kentucky windage, bro ...
Filippo
Hmmmmmmm guess i dont speak Morrelli ? laughing6-hehe laughing6-hehe
OK Im gonna take the pickguard apart ( prewired pickguard ) and do a layout and hope I get it right , i am a redneck ya know ! ;) and if it allll goes south on me i am gonna say Fillipo was my instructor ! pfft :D
PostPosted: Mon Jan 23, 2012 3:29 pm
Wud, you have a pm.
PostPosted: Mon Jan 23, 2012 3:39 pm
First name: Big
Last Name: Jim
Thanks Mike that will work Perfectly . I have the humbucker cutouts done , this will help me finish what i dont have ! I owe ya a beer !
PostPosted: Mon Jan 23, 2012 4:49 pm
You,re welcome, Wud!
As for the beer, i don't drink alcohol. Doesn't matter though. You don't owe me anything. This forum and the people on it have helped me out so many times I can't even count. I'm glad to be able to give a little back.
PostPosted: Mon Jan 23, 2012 5:47 pm
First name: Big
Last Name: Jim
Added this drop top I puurcased about 1-1/2 Yrs ago on the classifieds . I think its gonna look pretty nice .
Which brings me to a Question , does anyone Bind electrics ? I think a wood binding would look better than just a transition what do you guys think ?
PostPosted: Mon Jan 23, 2012 7:40 pm
Wicked cool piece of burl!
As to binding, I've seen several bound strats. Looks to me like the biggest concern would be how to bind around the forearm contour. But I have seen it done(don't know how). I've also seen a lot of bound strats without the forearm contour. I think it's a cool look, although there are "purists" for lack of a better word, that think binding doesn't belong on a strat. pfft
PostPosted: Mon Jan 23, 2012 7:55 pm
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
Cool piece of wud.
Does anyone else see a camel's face in the bottom?
Kevin Looker
I'm not a luthier.
PostPosted: Mon Jan 23, 2012 9:23 pm
First name: Big
Last Name: Jim
klooker wrote:
Cool piece of wud.
Kevin Looker
laughing6-hehe laughing6-hehe laughing6-hehe laughing6-hehe laughing6-hehe now that you mention it YES laughing6-hehe laughing6-hehe This guitar will be the desert camel !!!
PostPosted: Mon Jan 23, 2012 10:17 pm
The horns make it look like a goat head to me.
Old growth, shmold growth!
PostPosted: Mon Jan 23, 2012 10:58 pm
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
Might be a camel, goat or a sheep.
Definitely is some kind of animal!
Very nice piece of wood.
Just carve the contour
and miter the bidings.
Gonna be sweet!
Just don't sand that top much more.
The eyes will disappear,
PostPosted: Tue Jan 24, 2012 12:11 am
First name: Virgil
Last Name: Mandanici
State: FL
Camel nose or camel toe wow7-eyes laughing6-hehe Eat Drink :evil: laughing6-hehe :shock:
Wicked wood Wud
PostPosted: Tue Jan 24, 2012 2:40 am
First name: Stuart
Last Name: Gort
That guitar looks possessed....by a sleepy camel? :)
StuMusic
PostPosted: Wed Jan 25, 2012 8:49 am
First name: Big
Last Name: Jim
I sat and looked at this top last night for a while and decided I am changing direction on this a lil bit ..... If i use the prewired Black pickguard most of the burl will get covered .... sooo im thinking of routing a pocket from the back and just holes for the knob shafts in the lower bout in the clear area ...... then using a " clear " lexan pickguard . That way the entire burl should show nicely .
What do you think ?
PostPosted: Wed Jan 25, 2012 10:31 am
First name: Virgil
State: FL
I would nix even the lexan and just use as much as the back real estate as possible to make it happen!
PostPosted: Wed Jan 25, 2012 10:40 am
First name: Roger
State: Oklahoma
I'd probably skip the lexan. IMHO, with a good enough finish, there won't be a need for one. Of course I'm not a fan of pickguards in general. I don't have one on my Cornerstone acoustic, my LP copy, or the telecaster I built idunno
PostPosted: Wed Jan 25, 2012 10:43 am
First name: Big
Last Name: Jim
On the control cavity thats no prob , I can aslo use a amp plug on the edge of the guitar , so that leaves the humbucker holes and some trim rings . Soooo you dont feel that even a thin clear pickguard is necess?
Or maybe the stickon sheet pickguard people use on acoustics , cut to fit a small area ?
PostPosted: Wed Jan 25, 2012 2:07 pm
First name: Virgil
State: FL
I's treat it like a carved top - let that wood speak for itself!
